Interpenetration of solid
fstopelli-2
Hello!
I would like to prevent the interprenetation of solids, that are "linked" by fasteners...
You have any idea?
Thank you
Good Life
Federico
6 REPLIES 6
fstopelli-2
(To:fstopelli-2)
So, I'm forced to make a non-linear analisys?
It is not possibile to avoid it?
The other option would be to use a bonded interface - that would prevent interpenetration, but would also prevent separation.
In some other analysis package there's a sort of 'tied' interface, which keeps parts in contant but allows them to slide, but I'm not aware of anything equivalent in Mechanica.
By definition, if you want surfaces to be able to separate but not penetrate, that's a non-linearity...
example attached (assembly).
regards
paul
fstopelli-2
(To:skunks)
Sorry, but I don't see it
settings for a bolt:
contact:
regards
paul
PS:
PTC:"
The fix separation option for the fastener is preventing the parts from
   separating at locations where they should separate. Hence, the results
   for this analysis ... inaccurate. You should turn off the fix separation
   option for the fastener and ... introduce a contact interface
   between the parts that are connected by the fastener."
regards
paul
