IpfcXToolkitGeneralError and IpfcXToolkitCantModify
kjl.cool
1-Newbie
2 REPLIES 2
Jeremy,
Can you check if the environment variables are set:
- PRO_DIRECTORY = Pro/ENGINEER <load point=">
- PRO_COMM_MSG_EXE = Full path of pro_comm_msg.exe
Rochan Hegde
Productspace Solutions Inc.
Rochan,
thank you for your solution.
know i am not so sure about the variable PRO_DIRECTORY.
i installed proe with default path, (PS:Windows 7, 64bit), i set PRO_DIRECTORY=C:\Program Files\proeWildfire 5.0\bin\
cause in the computer which can run my app successfully, i set the same values.
and whats more, now it always throwIpfcXToolkitCantModify, does it mean that i havent get anauthority?
In Reply to Rochan Hegde:
Jeremy,
Rochan Hegde
