Material Report
Chris3
20-Turquoise
Material Report
ANSYS has a report option so that when you are finished with an analysis
it outputs the results and also a list of all the materials used. Is
there something similar for Mechanica?
I know I can click on a material and then choose Show -> info and then I
could probably copy that HTML into a report. I might even be able to
automate that with a mapkey but that would be a lot of work.
Does anyone know of something easier?
Chris
Chris3
20-Turquoise
(To:Chris3)
Never mind - I found it. File -> Export -> HTML Report
Chris
