Not able to insert Manikin
Qmatic
7-Bedrock
I have no luck in inserting the manikin in my assy. When hitting the "insert Manikin" button I can only select the ptc_manikin.asm  manikin and after doing that selection I get this error message; "Could not find proper interfaces in manikin to insert. Please re-select."
Any one know about this?
Mahesh_Sharma
22-Sapphire I
(To:Qmatic)
I am not an expert in Windchill. You may submit a support ticket. And mention clearly that issue is reproducible only in linked session of Creo.
9 REPLIES 9
Mahesh_Sharma
22-Sapphire I
(To:Qmatic)
Can you share some video for the same? Additionally test this in standalone session (Without Windchill, if Working with Windchill), without any config file.
Yes, I'm working in Windchill. But I don't know how to start a session without starting Windchill?
Mahesh_Sharma
22-Sapphire I
(To:Qmatic)
Start a new session of Creo, File > manage Session > Server management > Double Click on No Server. This will make session standalone
I don't have the option to insert the Manikin when I start Creo without Windchill. I don't even find the Insert Manikin function in the search function.
Mahesh_Sharma
22-Sapphire I
(To:Qmatic)
In standalone session create a new assembly > Manikin > Insert manikin
Yes, that works. While I am in stand alone mode I can insert the Manakin. Why does it not work in Windchill enviroment?
Mahesh_Sharma
22-Sapphire I
(To:Qmatic)
Thank you very much! I would never been able to find that bug without your help! Smiley Happy
RandyJones
(To:Qmatic)
You need to import all 8k+ manikin objects, into Windchill, in order for Manikin to work with Windchill.
https://www.ptc.com/en/support/article?n=CS50849
