Not converged!?
teosoontong
Not converged!?
hi,
I analyze a stress distribution of a structure using static analysis in
Pro/MECHANICA integrated mode, what if i check the measure of convergence
of the analysis and find that it is not converged, what should i do to
make it converge? Please advise, thanks.
regards,
Soon Tong
Hi Soon Tong,
What method of convergence did u use : SPA or MPA ?
If MPA, u can view convergence plot of say vm stress vs p-pass. This
will give u a clue of yr analysis. There could be a singularity problem
in yr model, maybe a pt load or pt constraint or a sharp inside corner.
Hope this help.
Roland Lim
