Notification for [File->Close Window] action
Highlighted
Newbie
Anyone knows if a notification for [File->Close Window] exists?. I tried all the model related and window-change notification types, but none of those are triggered by a window close. Also, I don't see anything obvious in the ProNotifyType enum corresponding to this.
TIA.
3 REPLIES 3
RE: Notification for [File->Close Window] action
TIA,
I can see your frustration. I have not accomplished this but I would
Hello all,
Notification could by done by using technique described in:
file://<proloadpoint>/protoolkit/protkdoc/manual0/menus.htm#476
for ProMenubuttonPreactionSet() and ProMenubuttonPostactionSet(). The
manual provides an example : 'Example 11: Asking for Confirmation on
Quit Window'
HIH.
Feliks.
@Patrick,
PRO_WINDOW_CHANGE_POST was the first thing I tried. No luck.
@Feliks,
Thanks for the info. Your suggestion might work. I will know as soon as I find out the button name for this.
