Pipe taper reamer
cncwhiz
Pipe taper reamer
Does anyone have a pipe taper reamer for a 3/4-14 hole?
Terry
I guess from the results I am getting, I did not explain good enough. I don't need a actual reamer or a tap as that I use threadmills. I am looking for a "model" of the tapered reamer for a 3/4-14?
No, but I have the UDF files of pipe thread curves if you would like to single-point the pipe thread with a trajectory sequence.
