Problem with ProMessageStringRead()
Hi all,
I am using ProMessageStringRead() to get the Yes or No value
Below is the portion of code
// Prompt the user to enter some value, include default in message
status = ProMessageDisplay (MsgFile,"USER Do you want to add ?
[N]:");
// Get their answer and check the return value
ProName w_answer;
char ans[8];
status = ProMessageStringRead(8,w_answer);
This works fine but problem is when I am running this
It shows the first message in Prompt message correctly
but instead of showing Yes / No buttons it shows
tick mark(yes) / cross mark(no)
The text file contents are as below.
%USER Do you want to add ? [N]:
Do you want to add ? [N]: ||| No
So any Idea for this?
Pankaj
