Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I find a reboot not always possible so what I do is start a second ProINTRALINK client and log in, then ProENGINEER will, most of the time, start-up in the first ProI-client. You still have the reboot if it does not work.
