Simulation API for Creo Object TOOLKIT Java
lptak
1-Newbie
I have fiured out that Creo Object TOOLKIT Java does not support Simulation API. My question is if PTC plans to introduce Simulation API into Creo Object TOOLKIT Java? If yes, when can it be expected?
Best Regards
Lukasz
5 REPLIES 5
Hi Lukasz Ptak, I've moved his Thread to the Creo Customization space to increase your chances of an answer.
rmcboaty
7-Bedrock
(To:lptak)
I saw a pdf somewhere that stated that there will be a lot of development on the OTK in the next two versions.
that means in 2-4 years probably.
i am not a PTC employee, just for the record.
lptak
1-Newbie
(To:rmcboaty)
Peter, Robert - thanks for your input.
In the meantime I received following information from PTC:
This is something we have on the radar, but have not budgeted time to do the work. This would need to be prioritized for a future release….no earlier than Creo 6.0.
That concludes the topic.
rmcboaty
7-Bedrock
(To:lptak)
5 - 6 years then, looooool.
did you ask your VAR about that or on this forum?
do you perhaps know if the PFC methods will receive any new development or will they stay as they are? (i.e. no new dev).
lptak
1-Newbie
(To:rmcboaty)
I received that answer after contacting PTC support directly and opening separate case.
Unfortunately I have no further knowledge about future development.
