Spring endurance calculation using Mechanica
dm-3
1-Newbie
I want to calculate endurance of spring in Wildfire 5.0.
I want to apply a load of 600N, strokes doesn't matter for 1 lakh cycles. The test speed is 2Hz.
Kindly suggest how to solve this in Mechanica.
Dhinesh
3 REPLIES 3
Well, Mechanica can easily calculate the stress at your maximum load, and unless it's a really big spring the dynamic load at 2 Hz can probably be neglected.
After that, you'll need to use some fatigue data for your chosen material, and probably do some good old-fashioned maths with it...
Hi Dhinesh,
It's possible that PTC's Fatigue Advisor could help you with the endurance calculations.
Tad
346gnu
(To:TadDoxsee)
Hi Tad,
Anything in the pipeline for Fatigue Advisor?
Assemblies? Load histories greater than 100 lines? Better CPU usage (only one core seems to do anything)
Charles
