Symbol in model tree while in NC
Level 5
Afternoon All,
Has anyone run across the vertical black line symbol, shown below, while
in NC?
The sequence is completely defined and the play path looks good. Anyone
have a clue what this symbol is indicating?
Brian
4 REPLIES 4
I found the issue. A reference in the volume definition was causing the
issue. Not sure what the symbol means exactly, but it was present in
the volume sketch also. Once the reference was cleaned up the symbol
went away.
Have a good day
Brian
It looks a lot like the "packaged" icon you get when something isn't
fully constrained.
Highlighted
It looks like the "packaged" icon you get when something isn't fully
constrained. If you look at the pictures below you will see detail 502
has a single rectangle. This item is only partially constrained in its
assembly. Below that you will see two features (SB1_S1 and SB1_S2) that
have double rectangles. These are features in another model that
reference the partially constrained detail (502). The double rectangles
help you know that something that these features are referencing is not
fully constrained.
Tom
RE: Symbol in model tree while in NC
Parallel lines plus a small hollow square icon is saying that the component is assembled by referencing a frozen component.
