Tip/Technique - Using Macros in Excel with SmartAssembly
Newbie
First you need to build the macro in the excel spreadsheet. If it is a simple macro, you can just record it (and call it with an empty array, but if you need to pass variables into it, you will need to do something like the example below.
Macro VB:
Sub create_csv(myfilepath As String, myfilename As String)
ThisWorkbook.SaveAs myfilepath & " & myfilename, _
FileFormat:=xlCSV, CreateBackup:=False
End Sub
PRINT "FIRST ARGUMENT FOR MACRO = %" TEMPSTRING
ADD_ARRAY_ELEM arrayArgumentsMacro TEMPSTRING
! create the filename value for the macro
TEMPSTRING = <new filename=" string=">+".csv"
PRINT "SECOND ARGUMENT FOR MACRO = % " TEMPSTRING
! call the macro
EXCEL_RUN_MACRO "create_csv" arrayArgumentsMacro
