Hey,
I have a Section with a line with starting point (0,0). Now I want to get world coordinates(in the Solid CS) for this line. It may be like (100, 140, 10)
I read in the User Guide, that there is an option to transform coordinates using rotation matrix(and probably not only rotation but also shifting as long as Matrix is 4x4).
Say I have an object of pfcTransform3D class, now I have to setMatrix and then I will be able to TransformPoint
The question is: To setMatrix, I have to know coordinate system's base vectors (for xOy are (1, 0) and (0,1)) for both (target and source CS's). Where can I get these vectors for my Section and Solid (probably (1, 0, 0) and (0, 1, 0) and (0, 0, 1) ) and Shifting vector?
Thank you in advance,
Artem
OK guys,
I think, I managed this.
wfcSection_ptr class has member GetLocation(), which returns pfcMatrix3D_ptr.
pfcTransform3D constructor arguments are: bool, pfcMatrix3D_ptr.
So final code should be close to:
pfcTransform3D trans(true, section->GetLocation());
pfcPoint3D_ptr point = pfcPoint3D::create();
point->set(0, 0);
point->set(1, 100);
point->set(2, 0);
pfcPoint3D_ptr point_new = trans.TransformPoint(point);
It seems, that is what I need.
OK guys,
point->set(0, 0);
point->set(1, 100);
point->set(2, 0);
