can any body explain...
vemanamar
Dear Users,
can anybody explain me what exactly the following phrase mean,
"giving up- peer appn and/or msg module is not alive"
regards,
Amar Vemanaboyina
Hi Amar, ProE shows this message when your toolki application is running
without a ProE session loaded or if pro_comm_message.exe process is not
loaded. Usually it happens when your toolkit app is not working right and
does some wrong action to ProE that causes it to fail.
Message from "Amar VemanaBoyina"
<amar.vemanaboyina@idolafori.com>@lists.ptcuser.org received on 10/11/2006
07:00
| | 10/11/2006 | |
| | 07:00 | |
Your toolkit application crashed Pro/ENGINEER and the communication
between Pro, pro_comm_msg.exe, and your app has been broken.
Patrick Williams
