Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Not quite sure what you're asking, Billy. Can you elaborate?
To: -Subject: [proecam] - gage toolingFrom: Billy.Carwile@reedhycalog.comDate: Mon, 24 Mar 2008 13:13:33 -0700 Has anybody done anything with gage tooling in Pro/Man?
