Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
In MFG SETUP>OPERATION select the OUTPUT tab, un-select the Use Default radio button and enter in the name of the model instead. This will be used for the NCL file name.
