traceback.log
BobMonat
traceback.log
Unfortunately, my application crashes on a customers computer and a
traceback.log file is generated.
The following is the beginning of the traceback.log file:
bfrandsen
6-Contributor
(To:BobMonat)
Hi Bob
Could the difference in traceback.log be a matter of debug/release versions of your program or that you have the Visual Studio environment on your developer machine.
The given log seems to reference memory space with no link to code line numbers.
/Bjarne
Bjarne,
I used a debug build. In the C/C++ Generic, I set Debug Information Format
to Zi. In the Preprocessor symbols, neither _DEBUG nor NDEBUG was set. In
the Linker Debugging, I set Generate Debug Info to Yes. These are the
settings I had used successfully on a development machine.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
On Thu, Jul 17, 2014 at 1:53 AM, Bjarne Frandsen <->
wrote:
> Hi Bob
> numbers.
> /Bjarne
> *From:* - [
