web\link and workingdirectory problem :-(
vpapa
Hello Andreas, and thanks for the response.
Unfortunately it did not work.
I try to explain better, the api ChangeDirectory works well in that it
successfully moves the workdirectory in the new folder.
However, if I do File \ Open menu, the OpenFileDialog always shows me the
old workdirectory, it is as if not properly set the default path of the
folder. Its possible set this defaultpath ?
0 REPLIES 0
