Ability to utilize Views, and Simplified Reps from PVZ
We use Simplified Reps often to create the views with the components needed.
So far using Creo Illustrate 5 I have not been able to use any simplified reps and import the PVZ into Illustrate. This lack of functionality (or absence of how to get this) has caused us to bypass Illustrate and use Exported images from Creo Parametric Drawing and import these images into Adobe Illustrator.
1 Comment
Granite
You should be able to create a figure from a Simplified Representation in Illustrate 5.0 & 5.1.
In the New Figure dialog they are listed as Alternative Representations (Simp Reps are Alternative Representations in Creo View & Creo Illustrate).
Can you confirm which release of Illustrate you are running, and that you don't see any Alternative representations listed in the New Figure dialog?
