Security Alert Log4j Security Vulnerability. Click here to know more.
Add option to Creo View "Print Multiple Items" to use the settings in the active window.
Using Creo View 2.0 M030.
Today, you can create combined views in Creo and then publish them to Creo View.  Once in Creo View, you can adjust how they look by tweaking things like Render Mode (shaded, wireframe, etc.) and Filters (datum curves, planar annotations, etc.).
But, once you're done tweaking and want to print those views using "Print Multiple Items," those settings are not maintained.  The prints will revert to the as-published state.  In other words, what you see in the active Creo View window is not what is printed.
This enhancement request is to add the option to the "Print Multiple Items" command to maintain all those tweaks and apply them to the views before printing.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
