scenario :
Create a section. Open the 2D view, and create some measurements, add some notes etc... in this 2D view.
Save the section as an annotation: the box "include section" is checked.
Result : When I open later on this annotation, the section is here, the cut plane and its position are kept, the 2D view is here but all markups (measurements, notes etc.. ) made in 2D view are lots.
Idea: the 2D Section view to retain markups
If dimensions are taken in this 2D view, with the cut plane at this position, it is because this is important to see and may be critical from a design point of view. Annotations are excellent ways of sharing between colleagues but in this case, many relevant data are lost.
This functionality is very important for our daily activity: designer, geometrical architects, aftermarkets etc.. are requiring markups to be kept in d view
