Change the configuration standard file (.zip) of an existing illustration
Hello everyone,
I think it should be good if it will be possible to change the configuration standard file (.zip) of an existing illustration.
For example to add new elements in this illustrations if a new Config standard file is defined with symbols, annotations, insets, ...
Regards
1 Comment
Regular Member
This idea is similar to https://community.ptc.com/t5/Creo-Parametric-Ideas/Add-quot-change-standard-quot-functionality-in-Cr... .
If you agree to this one, please also vote for that one since it has already reached a higher status.
