I'm not sure that would be an advance for Illustrate; let me explain my mind:
without Windchill, when you import a native parametric file into Illustrate, or View it's almost the same, you expand time to open the assembly (there is a sort of convertion to creo view file in background) and you lose all attributes, sometimes needed for the illustration.
I think you will have a better use if you custom the publish service to create a post-publication and have a PVZ file available in Windchill.
with this best practice, you also can manage the PVZ evolution if you choice a manual post-publication.
Yes you have right Ronan , same here, need import pvz to see attributes... ( Another Idea maybe CS143270) But no need them for now that's the reason i have not detected this issue functionality
Ido not thinkthis ideawill be read andapplied byPTC, I just feel thatthe toolis not finished and this is my 2 cent.
you have to apply a publish rule to your CAD Worker to post-publish tha assembly; that creates automatically the PVZ file as a dynamic document, and it's linked to the asm.
we are already publishing pvz Files with the CAD Worker.
Our systemadmin told us that the published pvz is embedded and not useable with Creo Illustrate.
So his advice is to publish an another pvz in a separated windchill directory.
If we do a workflow like this, we have to publish all relevant Assemblies every night, because if some subassembly change, the mainassembly pvz wouldn't take notice of that.
To cut a long story short, we are not satisfied with the PDMLink system.
Now we are use the workaround with the import - export.
In the near future we would like to use the automatic published pvz, but this will slow down our system-performance.
We are also trying to use Creo Illustrate 3.1 (datecode M010) together with PTC Windchill (10.2 M030-CPS19) and PTC Windchill Workgroup Manager (10.2 M030-CPS18). Our plan was to import native .prt and .asm files from Windchill to Creo Illustrate, creating a link to the original file and then make assembly animations from them. If some changes were made to the original files, the updates would also carry over to the illustrations in .c3di files. However, this is impossible, because the files have to be downloaded locally to hard drive from Windchill and the links to the original files are thereby lost. Creo Illustrate does, however, support importing of .stp-files from Windchill. This is not an optimal solution either, because we would have to create duplicates from the original files in .stp file format and changes made to the original files would not carry over. We are not satisfied with the compatibility of Creo Illustrate and Windchill, because we can not work with PTC:s own native file formats. At the moment, if we would like to apply changes made in the original models located in Windchill to the parts used in Creo Illustrate, same work would have to be done twice, which is not acceptable. I hope that PTC will find a way to import native files in Creo Illustrate from Windchill, as working locally is not a viable option.
I have the same issues as everyone has mentioned and would like PTC to investigate an updateable link between the content generated in Creo Illustrate and the source Creo 3D CAD file.
