Creo Illustrate smaller arrow head & snapping at the top
In Creo Illustrate you can change the line thickness of the leader, but not the size of the arrow heads of the annotation.
Also the snapping seems does not seem to be at the top of the arrow, this causes the snap to miss it's target sometimes (see arrow pointing the pin of the piston).
These are snapshots from the latest Creo 5.1 F000.
So what would be good improvement:
  • ability to change size of arrowheads
  • Snapping of the arrow at the top of the arrow
1 Comment
Perryscope
3-Visitor
Still a valid improvement,  still an issue in 7.1:
- Arrows overshoot the part for small parts as the tip of the arrow is not on the attachment point for the callout on the part
- No settings for changing the size of the arrow
- Arrows deform (as they are 3D cones and the callouts can be placed at different depths)
