Creo View Cross Section cut side
Quarter cuts only cut the inside angle, within the 90deg, and there is no way to have it cut the outside, the 270 degrees.  You can keep flipping but will not get the outside cut.  Add functionality to cut the negative side of planes.
2 Comments
Regular Member
Does this go anywhere?  Does PTC listen to these ideas?  How do we know if they intend to implement?
Sapphire II
There is this long drawn out discussion on PTC and Ideas here https://community.ptc.com/t5/Creo-Ideas/Does-PTC-ever-read-these/idi-p/455409
The communication is "poor" to say the least. With the current forum, there are fewer communication tools with respect to Ideas.
There are some very good ideas that have been posted for 10+ years that have never been implemented.
I've also seen some PTC activity on Ideas quickly, so it's not all bad.
