Creo View capability to correctly open AutoCAD files with Blocks from Windchill
Creo View can open an AutoCAD file with Blocks if opened natively from a folder.
If the same file, along with the blocks, is stored in Windchill the pvz files contains the drawing and the blocks.
In this case the drawing is rendered without the blocks.
It should correctly render these drawings from a Windchill pvz file.
