Security Alert Log4j Security Vulnerability. Click here to know more.
Creo View custom notes and annotations
It should be possible to add custom notes and annotations in Creo View, the same way as you can do in Creo Illustrate.
In Creo View you can use Note templates which is good, but this requires unneccessary steps compared how it is solved in Creo Illustrate.
In Creo View you require 6 steps to add a note based on a template
In Creo Illustrate you require 2 steps.
Suggestion:
Introduce same solution in Creo View as in Creo Illustrate
1 Comment
olivierlp
Community Manager
Status changed to: Archived
