Creo illustrate can display the "flexible" function setting of creo parametric
At present Creo illustrate and not display creo paramteric of "make elasticized" feature set, because we will be used by creo parametric to a lot of "make elasticized" is set, it is expected creo paramteric of "make elasticized" feature set creo illustrate can be used to read and display
Related Case Details: 15208538
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=15208538
