When using CreoView to markup a 2D drawing it would be nice if there was a way to copy and paste an existing view and also things like notes. It can be a common practice when doing a markup to take some existing part of the drawing, copy it to a new location, and add a note about what should be done. For example a view may be copied to indicate the view must be moved to a new location or a similar view created in the new location. Many 2D PDF editing/markup tools provide a way to take a snapshot and then paste that snapshot back onto the 2D PDF.
