CreoView: Single Click Exiting & Multiview Tabs
1) Allow single click exiting of CreoView by either method:
   a) Allow option to close CreoView window without warning about navigating away from page  (Giving a warning would still be useful in the specific cases where there are unsaved  changes)
   b) Allowing to Add "Exit CreoView" to Quick Access toolbar  -->Either method would reduce 3 click and 1 mouse motion to just a single click saving  design time and avoiding user annoyances.
2) Tabs for QUICKLY and EASILY viewing multiple CreoView windows at a time in CreoView.
   (or simply removing the limitation that only one CreoView window can be open at a time).
2 Comments
Moonstone
1) I found an option in the latest Creo View to close with 1 click and then was able to add it to my quick access toolbar!
ProductIdea--CreoView--Options.JPGIn Creo View go to File, Options, Customize, All Commands, Exit (then Add too quick access Toolbar.  1 click closing...just don't accidently hit it when you don't want to.
When marking up Creo View it does infact recognize that markups have not been saved and prompts what you want to do.  It would be nice if this functionality was tied into the windows Red X in the type right of the window, like every other program works.  At least there is a work around for now...till they hopefully fix this.
2) There actually are tabs and they work better now.  It would be great though if the tab location was shown how most other programs show them and if they could be broken out of the main window simply by dragging (as is standard with the latest web browsers).  So although Creo View has tab functionality there is definately some room for some great improvement.
Community Manager
Status changed to: Archived
