Issue: Unable to load my checked out work in Creo View 2.
(Issue existed in WC10.0 and carried over into WC10.1. Reference cases 10627953 and 10650929)
PTC Logic: If object is changed or in process of being changed than it is unpublished and should not be loaded in Creo View.
Use Cases:
Proposed Solution: Provide an option in Creo View or WC10.1 to load the latest version published in Windchill.
Reference attached picture showing assembly checked out and not loaded in Creo View.
