Expand vectorized output possibilities in Creo Illustrate
It would be good to expand vectorized output possibilities from Creo Illustrate.
When comparing against Arbortext ISODraw, output possibilities are very poor. For vectorized output, only .cgm or .svg is possible. It would be good to have the .pdf option as well, for example.
If a vectorized pdf is needed, users have to export to .svg and generate a vectorized pdf with the help of Adobe. Why not generate it directly from Creo Illustrate?
