Currently Creo View Adapters cannot publish inventor flexible assembly correctly
Steps to reproduce:
1. In an Inventor assembly, make a sub-assembly “Flexible”
2. Re-constraint a part of the flexible sub-assembly and save
3. Publish the assembly with inventorbatch.bat or inventorpublish.bat
Expected behavior:
Representation should same as the assembly in Inventor
Observed behavior:
1. representation in Creo View is not same with the assembly in Inventor
2. It seems that the “Flexible” is ignored by Creo View Adapter
