Leader lines on stamp
When I change the display resolution, all the stamps in my annotations set are moved in Creo View
The idea is to fix my stamp on a reference. For this, it could be interesting to use a point on the stamp as a reference or to attach a leader line from a reference to the stamp.
2 Comments
StephenWilliams
Sapphire II
What is a stamp? I've never seen "stamp" in Creo Parametric.
eboutant-2
Guest
I add that it is in Creo View.
A stamp is an image that you put on you visualization as "Caution, Hot" or "Approved".
