Permanent Watermarking in View
Would like the ability of Creo View to permanently watermark the PVZ viewables.  This can either be embedding the current displayed watermark when the File -> Save As function is executed in the client or the ability to define a permanent watermark that is separate from the other watermarks (e.g. Copyright or Proprietary, ITAR notices)
Current functionality allows for watermarking the display in the client.  When a PVZ is loaded it will show the appropriate watermark that is stored on the server side or client side preference.  If a user then saves the PVZ to the hard drive and opens in a stand-a-lone client, the watermark will not be shown.
Use Case:
User wants to save a PVZ to the hard drive to email to a customer or supplier.  Once that PVZ is opened outside of the Windchill environment want the watermark to persist.
2 Comments
ptc-4547054
Newbie
Hi, Eric. I am facing the same problem! I am very frustrated about watermarking with Creo View. I thought the users couldn´t disable the markers but it´s not true. And worst I have to set each Creo View asset up to enable watermaking at printing.
PTCModerator
Emeritus
Status changed to: Archived
