Support of part level simplified reps in Creo View
Currently one can create a nice set of annotations with Creo Parametric 2.0 which can be published to Creo View. This functionality can be used to create 3D drawings which streamline design process and simplify data management. Data distribution (deliverables and application) can be arranged via Windchill till shop floor level.
When one creates annotation sets for sheet metal structure, there is a need for formed and flat states (bend and unbend) of geometry with supporting annotations for manufacturing. This can be done either via simplified representations or Family Tables. Later one is not an solution since it really does not simplify data management in PDM.
Therefore a support for part level simplified reps in Creo View is needed.
9 Comments
Newbie
Good idea
Aquamarine
Mikki,
Can you add the following tag? - "June 2016 Technical Committee"
This is a topic we would like to discuss for the meetings.
Sure, Billi 🙂
Aquamarine
This doesn't appear to be designed into the Creo 4 adapters, unless I'm missing a setting in WVS properties or adapter settings.
Can somebody at PTC confirm that this is not designed in yet?
Community Manager
It seems that Creo 5.0 is still missing this one; only include/exclude part are supported. There is more need for this improvement due expanding Creo Illustrate usage. Current workarounds, which do not make data management easier: - Familytables - Inheritance - Flexibility
Aquamarine
Thanks for evaluating.
There is no doubt the need is there...this is just one piece of the big puzzle to enable the holy grail for us which is to have the WTPart metadata, Creo model and the lightweight representation synchronized at the latest iteration in Windchill.  Family tables result in processes adding 500% more time.
Also, at this point it is just a black eye for Creo View when a user doesn't see what they are expecting.  I had an engineer email me a couple weeks ago asking for the other member on his team to not use part simplified reps because he wasted time looking at incorrect information.  I know a lot of companies depend on Family Tables...but I'm not one of them.  Let's put the pieces of the puzzle in place to allow for the companies that don't like family tables to get away from them!
Marble
Status changed to: Delivered
Hello all who've replied on this.
We have implemented this important feature in the Creo View 6.0 release in June 2019.   In order to take advantage of this capability in Windchill there are corresponding changes required in the Windchill Visualization Services.
Those have now been implemented and are available in Windchill 11.2.0.0, 11.1 M020 CPS 11, and 11.0 M030 CPS 18 (to be released shortly).
Suberb! Thank You!
