The Ability Import Explode States from Creo Into Creo Illustrate
I believe that it would be a game changer if Creo Illustrate could use explode states created in Creo.
-Bill
2 Comments
ptc-6749480
Regular Member
I figured out how to get this to work.
1) You first need to edit the recipe file to "Output Author States" and "Output PVZ."
2) The next step is after you save the PVZ from Creo, you need to find the PVZ file and change the extension to .zip
3) After this, you have to extract the .zip and use the PVZ from the extraction.
*Note
I wasn't able to see any parts or assemblies with the original PVZ exported from Creo.
The only PVZ that worked, was the one from the extraction.
---Bill
agarland
Amethyst
Any explode states in the source data should be available under the "Preset Explode" button in the Home ribbon.
