Security Alert Log4j Security Vulnerability. Click here to know more.
Wavefront OBJ Export ability
Ability to directly export from Creo View to a Wavefront OBJ & or a .slp file.  There are many applications that are using OBJ or SLP as the only inbound format and the conversion process should not be as hard as it is today!
2 Comments
AdamManfredonia
Ability to export OBJ is superior to export to VRML.  VRML does not support surface normals whereas the OBJ format does, surface normals approximate surface structure to allow for smooth appearance which would allow for export from Creo View and then use the resulting data for renderings and animations.
BillRyan
Also an idea to Export FBX format out there.  Both FBX and OBJ are always being requested.
