add the CREO View Feature "capture the position"
when placing a 3D symbol in an illustration, I would like to define the assembled or positionned position as a fixed position!
this option exists in PTC CREO VIEW, and if you can add it in ILLUSTRATE, that would help a lot: if (by mistake) I press the "restore all componants position", I'm able to replace the symbols again...
PTC CREO VIEW button (in french) I need in ILLUSTRATE:
3 Comments
PTCModerator
Emeritus
Wes_Tomer
I agree -- and maybe I am saying the same thing here: it would be nice if you could put a tool back consistently in the same position (as though on a workbench) . For various steps I use the tool, and then return it to that position each time. This is different from "return to S-BOM position" because this is often not where I want the tool.
We are using Creo Illustrate to show step by step disassembly of a pump with specific tools, all laid on a workbench, exporting as a PVZ to Vuforia Studio, and publishing in AR
Ronan
I have a workaround for the sBOM components only:
move or assemble them in the restructure tool, they keep the new position.
but we still need this feature for the symbols as Wes explains.
