problem with illustrate
0 Kudos
Sir,
I am using creo illustrate 4.2. while using the the software I am facing some problem to select a particular   section of a part/the axis in the parts/surface. (like We do in creo if the front surface of the part we don't want to select or there are few surface in between the surface I want to select We use right click with some pause so We can escape the front surface) but in illustrate I can not do the same thing or option. (find the attachment in that you can see the problem to select round surface of the door to rotate that.)
                   The another problem which I am facing in illustrate is, when I have to select the parts from assembly if the part is below some parts then I have to hide the others above parts and then I can select the part which I want. is it there any shortcut key that We can use in illustrate for hide the parts.(as in My attachment I have shown You one other software's video  that I can temporary hide the above parts and then can select the part which I want. and after I release the shortcut key all parts while appear again.)
             kindly help Me to find the solution on this problem.
             please find the attachment.
                                  Thank You!!!
