Do We have to buy illustrator as an application addon or separate install or how does it work? Is there any way we can get a demo to try out before buy? We do a lot of installation drawings for military, and we are challenged with 2d drawings of interior assembly systems instructions. Want to see if Creo I is a good candidate and helpful.
Try requesting a demo version from a local reseller in your region - "PTC Partner Network": https://www.ptc.com/en/partners/partner-search
Thank you. I have connected the partners, Sales team. Will let you know how that goes. Thanks !
You're welcome.
Hi @Yogesh.T ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
