I would like the ability in sketcher to toggle display of strong & weak dimensions independent of each other. Use case: After importing or removing references on a complex sketch, many weak dimensions are created. While trying to constrain & dimension the geometry the weak dims clutter the display area. With current functionality, if you use the disp dims filter you can't see what you have strong dimensions on.
