I am relatively new to Creo illustrate and I wanted to ask for a guide to creating manuals (lets say I created a figure and now I want to display the figure and the respective sBOM in a manual format) since I saw that the software has the capability to do so. Also, I heard you can export it as 3D pdf or Jpeg is there a more optimal way or a standard protocol when creating manuals using Creo illustrate?
Thank you.
"Creo Illustrate 12.0.0.0 Help": https://support.ptc.com/help/creo/illustrate/r12.0/en/
Hello @Stephen_DeLeon,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
