Once I have found the drawings doing a search I should be able to place a checkmark by both objects then right click and have a Compare in CreoView option... Both versions of the drawing are automatically set up on Creo View to perform the compare.
Is this a product improvement suggestion or are you asking if this can be done?
Product Improvement.... Great concept horrible execution with the current process. It is so clumsy, once you figure it out you cannot remember how to do it the next time. Too many clicks.. too many steps.. It should be more streamlined. Very vallualbe process. Streamlines the checking process. Most people don't use it because it is to complicated and they can never remember how to repeat the process.
You may want to put this into a product improvement catagory instead of the general discussion. That way it is open for voting. The more votes, the better chance it has to be looked at by PTC.
