Creo Harness install
AD_9576949
2-Explorer
I have few harness installs that are needed to be converted into either .obj or .stl files. It is not convertible directly. IS there a alternative way to do those. Please help. As i need those to be worked on in a 3D software Blender. Which accepts either of those two file extensions as inputs
Hello @AD_9576949
Thank you for using PTC Community.
Your question has not received a response so far.
In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry? Specifically:
  1. Could you share more about the format or file type your harness installs are currently in?
  2. Also, are you using Creo Schematics or Creo Parametric, and do you have access to any export or conversion modules like Creo View or third-party tools?
This helps:
  • Identify the starting point (file format and Creo version).
  • Understand available tools or constraints.
  • Tailor the solution to their specific workflow.
This will enhance the likelihood of receiving valuable assistance from other Community members.
You might also find it useful to refer to this informative video on how to ask a good question. I'm also responding to bring attention to your question. Hopefully, another community member will be able to assist you soon.
Best Regards,
Vivek N
Community Moderation Team.
