I want to add an assembly structure
in symbols section of creo illustrate how do I do it?
Thanks in advance.
Aditya Gupta.
You need a .ol file.
In order to create it you need to:
1. Derive your assembly in order to make a single part file of it
2. Save it as .pvz file
3. .pvz file is an archive, so extract its contents and you'll see 2 extra files: "name".pvs and "name".ol
4. In Illustrate go to "Manage symbols" and click "add" -> choose the .ol file
Thanks a lot for your help, the solution provided did worked.
Thanks again.
Aditya.
