I was wondering if anyone has tried using Creo Illustrate with Creo Parametric models but using Siemens Teamcenter. I'm trying to find out if Illustrate can connect to Teamcenter, as that is a requirement for a new team I am working on if they want to consider using Illustrate.
This team is on Creo 10.0.3.0
Thanks!
Try also asking your question in the community here - "Teamcenter Users Forum": https://community.sw.siemens.com/s/topic/0TO4O000000MiicWAC/teamcenter-users-forum
Hi mwolfe
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
Hello vnamboodheri,
Thanks for pointing that out. Since I don't have specific examples considering this affects an entire companies' workflow in a hypothetical future use case, I think I'll just reach out to our PTC reps for the answer to this question.
Have a great rest of your week!
Mike
Will do. Thanks VladimirN!
You're welcome. Please post here if any solution comes from Siemens.
