Creo Illustrate - different Csys than in Creo Parametric.
Pawel_D.
Hi everyone!
I have created a model in Creo Parametric 4 for a AR purposes. I wanted to create animations in Creo Illustrate 8.1 but when I select "Transform" I cannot select the original Csys from Creo Parametric, only this one created by Illustrate itself. Can someone explain how can I change that? Is there an option to select when importing model to Illustrate?
Have you checked that all your construction geometry is visible:
If it is then I think you'll have to look at your recipe file for generating the pvz from Creo, as it looks like it's stripping too much out.
4 REPLIES 4
You can reposition the csys using the 'Select CSYS' option in the RMB menu.
This will allow you to align select a centre line or other axis to position the csys on.
Depending on what exactly you wanted to animate this may help.
Hey,
Thank you for a quick reply, I've already tried this option but it does not work in this case. I have a sphere where I can't select any axis, center line or edge to create csys 😞
Thank you Agarland, you really helped me! I was always using .asm files from Creo Parametric, never thought about saving as .pvz file to use in Creo Illustrate. Turns out that when I am using .asm file Creo Illustrate cannot show me middle point of this sphere:
Now it works perfectly 🙂
