Creo Schematics: When exporting sheets to PDF format and printing directly, all the labels are thin
JG_10170599
2-Explorer
I am using Creo Schematics Release 7.0 and Datecode7.0.0.0
In Creo Schematics, when exporting sheets to PDF format and printing directly, all the labels are thin and non-arial bold. I'm Using default font called "font". Just upgraded from Creo 4.0 to Creo 7.0 and the thickness and font type that they export are different. In Creo 4.0 all text labels are Arial Font and bolded depending on label which is what I want. When I moved to Creo 7.0 all text labels are thin and in non-arial font no matter if you export PDF or Print Directly. Is there a configuration that I am missing? From what I have investigated myself all of the settings seem to be the same. Thanks
BillF
(To:JG_10170599)
Have you changed the setting in Creo Schematics for the labels?    If it is set to "font", you get the default font.
We set all of ours to Arial 0.07" and they generate fine on the PDFs.
